mine has never made that noise until i blow the fuse for the dome light and power antenna then that function seems to work?
behind the dirvers side seat by the seat belt is a wire so if you open your door and your lights are on it goes ding--ding----ding.... anyway, that wire comes off easily and its not hard to put back on, not sure if u have to take a panal off though.. i dont have any panals in the back of my car
Thanks you guys i found the problem the wire was unplugged from the dinger, if you take out your bottom dash you'll see a metal plate underneath your steering wheel attached to that plate is your dinger box at the bottom, my wire wasn't plugged in, plugged it back in and worked just fine, thanks coldfire, but now when i went to take my dash off the little clip that holds in place got lost so i cant put it back on, does any body no were i can get another one?
