first of all. it is a 1998 gsr.
my problem is this.
when i hit my brights on the left(driver side) does not come on.
yes i have checked all the fuses
yes i changed the bulb
no it still wont come on.
The only thing that is weird is that when i hit my brights on the little blue headlight on my cluster does not come on since the bulb went out..
any help would be amazeing. thanks every one
check to see if the wire came lose, or if there is a short somewhere
Check the harness itself. Alot of times the bulb (especially those aftermarket hyperwhite bulbs) draws alot of current and the harness uses such a small gauge wire, it usually melts a little on the inside causing it to not work at all. This has happened to me before.
Fix: simply go to Pep-boys, Autozone or whatever you have in your area and purchase the female headlight harness for your particular year Teg. A little cut, solder and some tape and your good as new.
you could also check the wires with a volt meter if you have one. Check the voltage and see if theres power in the wire right before the plug. If there is, then your problem is the plug itself.
