kellogg97ls on Sep/25/07 said:
Ok, so today I took off the header gasket that came with the header and put the stock one back on. But, unfortunately, my car still sounds like a damn tractor!!! I noticed something interesting too....it only makes this "mechanical ticking" noise when moving and in gear, not when I rev in neutral, or rev at a stop.
Bringing a post back from the dead... I have this same problem. It only makes this sound when im driving and between 2.4-3k rpms. It doesn't do it while idling or just neutral reving. I recently had my engine swapped, and after I got the car back is when I noticed the noises. It looks as if the connection for the top half of the header and bottom half may be missing a bolt. Could this be causing the noise issue?
It's like a slight 'clicking' noise, but it's not the usual honda tick, because I can hear it while driving (over the running engine) from the driver seat. It sounds like its coming from underneath, near where the cat would be.
Any suggestions would be helpful as this noise is driving me INSANE!
Also, I have a noticed a high pitch whistle that takes place during this noise, and if I let off the gas while accelerating, both noises dissappear at the same time.
