I have a b20v with stock gsr head high compression bottom end and type r cams and noticed when letting off the gas there is a clicking noise in the head and sounds like something is jumping around in the head 3000-4000rpm, I went to a shop and they said the valve spring was cracked but the car drives fine, hope anyone has more insight on this?thanks
If the valve spring is cracked, then replace it. What additional information are you looking for if it's been diagnosed?
If it were a cracked valve spring the noise would be constant, but it only happens when letting off the gas
Pull the valve cover off and confirm
