1 - 15 of 15 Posts
My car is lowered with neuspeed sport springs and type r front lip, will my car be able to get onto these ramps without scraping? If i do actually get onto the ramp, will there be enough room to do an oil change or will space be cramped?
I have the black plastic ones, not the metal kind, and even at 0.75" drop, I can't get up on it. I don't even have aftermarket bumpers or lips, just stock front end.
I have a set of Rhino ramps, and there is no way to get a Integra on them without scraping even at stock height.I have a set of Tein S-Tech spring, so I have to kick them under the tire so the bumper doesnt move them, this is the only ramp that I've seen that could help you without scraping
Interesting??? When the car is on the ramp, is it high enough to get unreneath the car for an oil change? It looks kinda low.
you could alway get a little kid to do it
...j/k
or you could RhinoLine your lower lip so it doesnt get scraped
My teg is stock height and fits with about 1/8" between the flat part of the ramp and the lip.
Most people put down a couple layers of 1/2" plywood to get a start at the ramps. You could try that with some rhino ramps.
I had that prob with my lowered GSR and the rhino ramps
I put a small maybe foot long 2x4 in front of the wheel before the ramp. Worked fine for me. Its also a nice trick when you cant get a normal jack under the car, I just drove over the 2x4 to give it that xtra 2inches or so of lift
thats what i do...works good enough for me...and i have plenty of room to do an oil change...but i'm not lowered yet but will be soon...
Those look really good...I think I may buy some of those.
What I have been doing is using my stock jack to lift my front end up enough so I can get my other jack underneath and then when I am done I lower it on to the stock jack and then finish lowering it with the stock jack.
1 - 15 of 15 Posts
