I just installed a new drivers side half shaft, reason was because the outer CV boot was ripped apart and the grease all came out, and the it started to make its thumping/clicking noise.
After I replaced this the car still seems to make the same noise, only a little different (near the center of the tranny), can't figure this out since ive done this before on the passenger side.
Any info or thoughts will be greatly appreciated.
G3 Teg AUTOMATIC
I'm pretty sure even though you're an AUTO, you still have an intermediate shaft, which has a bearing that it goes through. Did you inspect that ?
Everytime I've heard of someone with the notorious "click", after replacing the shafts, usually with just re-mans from auto zone, the noise goes away and is cured.
