Got a good deal on some Oversized ITR pistons (.25) for 170 - so I will have my GSR block bored/honed out to 81.25.
Currently the only thing I want to add to my engine is head internal upgrades & cams -
My head currently has a little bit of a shave on it - right now about the same as b16/b18c5 head.
As for power goals Id be happy w/ around 190, a lil below - I know im a way off since im not going to agressive w/ the pistons.
My question is what questions should cams would you reccomend, i know some are good for certain compression ratios... currently with the setup (itr pistons/gsr head) im looking at the CR would end at 11.1:1 - if i took a layer off to 2 layers it goes to like 11.5.
My question stands heh - What cams would recommend for this type of CR w/o breaking the budget?(aka $700+) I just wanna get it right the 1st time w/o getting somethat will over/undercam
I Appreciate all of your help and advice guys.
Currently I have found skunk2 stage2 cams for 550 new - not a bad deal but then again I would have to upgrade internals, most likely w/ skunk internals -
I know i know... there is alot of "which cam should i Use? and i know stage 1 is like right around 11:1-11:4 and stage 2 is like 11:5-11:8
I guess i need a little guidance, its not final on the pistons, for currently i would be at like 11:1 w/ itr pistons, maybe im better off taking p30 pistons and take the deal on stage 2.
More or less i need what would be financially easier?
edit: forgot to mention, a skunk2 manifold will be coming, i will not retain stock gsr - exhaust setup is currently header-back, a 600+ header isnt in the budget currently
