Hi all,
Does anyone know the center cap diameter for the GSR Blades? I am in need of just one. Any help is great. Thanx.
I have this same question, and I also need just 1. Its for GSR Blades.
I measured one that I have and I came up with 55.5mm or 2 3/16" ... is this right? All of the Center Caps on ebay say they are 67mm or 2 11/16"
Help
one measurement
Aside from that, I can't really tell you. If you really just need one, why don't you go out and measure your current one so you know?
Someone needs to do this and confirm the sizes. It would be nice and very helpful. It would be gladly added to the common topics if it did happen.
Here, I'll start it up. I have center caps from the Mesh OEM alloy wheels in front of me. They meaure ~ 56.mm on the inside and 57.85mm on the face.
That comes to about 2.2" on the inside and 2.275" on the face.
The ones that I have are for the 15" mesh wheels, however they look just like the ones being sold here.
sak on May/13/06 said:
one measurement
Like I said, I measured one of mine, and it came out as 55.5mm/2 3/16" inches, on the face, while it was still on the wheel. That seems really close to one of yours.
Can someone else out there please measure one of yours off of a GSR Blade to compare with mine?
Thats pretty close to mines. I rechecked mines and you seem to have measured it from the face itself whereas I measured mines from the OD of the cap itself. Same thing, but at different locations.
Those measurements are correct. so make sure you get the ones that fit.
