Well since this local shop is running a special this month, 3 pulls with wideband o2 for $50, I figured I'd take the opportunity to get semi baseline numbers. I'm just wondering if there is anything that I should do or expect before I do this...
clean out your air filter, usually an old cat will clog op your exhaust too. **MEOW**
See if you can do anything quick to compare between runs. Like ignition timing at 14, 16, and 18 BTDC for your runs and see the differences in the power curves.
