How the hell do they come off? I was trying to pop it off at lunch today, but it was pretty secure and I didn't want to break it in half. Do i just pry it up until it pops off?
there's 4 or 5 clips, i can't remember, just pry up with a long thick flathead screwdriver, it's then clipped to the carpet, just pull hard from the carpet and the clips will pop out
Gotcha.
That the piece attached to the carpet by those little round discs?
If you mean that piece it just pops out, but I broke mine on the G2 cause I was replacing the carpet and all anyhow and just didnt care what happened to it since I got a new one anyhow
- Josh
You need to just pry them open carefully..the are clips underneath it that hold it to the body. I used a flathead wrapped in tape and carefully slid it along top and worked my way around. I then just used pliers to remove the clips from the body, since the black ones I was swapping in already had clips attached to them. Good luck.
