· Registered
1.There is an article about changing the gauge bulbs in G3 integras, I was wondering if there would be a major difference in doing it in a G2 integra. Would the size light bulb be the same?
2.Also there used to be a forum article with pictures and a good discription on how to have neon lights near our pedal light up when you turn your headlights on, does anyone have the picture that shows where you hook up the wires from the neons to the wires that turn on the headlights? I think there was a picture showing you where to hook up the wires to the fuse box to have the lights light up when the headlights were turned on.
Any information about either of these questions would be greatly appreciated.
· Registered
Yea i did try and do it the other day, switching the light bulbs behind the gauges, but I had some trouble taking apart the dash so I couldnt get to it. I was just wondering if anyone knew the size of the bulb so when I tried it again I would have the right size. once I figure everything out, I'll post it up.
· Registered
i've got the dash apart and the cluster is loose... i just can't figure out how to remove it. it feels really tight, i can hardly get my hand behind it. i've printed off the article, but i'd like a little further instruction from this point. should i expect to see 194's when i get it off?
thanks.
