i have a 2001 integra type-r, and i have two leaking injectors, i was wondering what are the side effects of it.
loss of fuel pressure, risk of exterior combustion
you're ITR is still under warranty, get it fixed!
yeah, i would of got it fixed today but the parts I ordered, lik the o ring and seals did not come in, and i heading to Pa today for hot import daze in Pittsburgh.
that's today? what state are you located??
he should be losing vacuum pressure if the O-rings are going. Just torque down on the fuel mounts. Any Acura dealer should have O-rings in stock. It's not like they are back-ordered. If the fuel ain't going in the combustion chamber, you're running lean in those cylinders. Don't even think about running wide open throttle. Read your plugs in those cylinders to see where you're at and you may have to retard the timing for safety until the problem is fixed.
It took some playing to get my RCs to seat correctly; just retorque them like MD said.
I couldn't imagin the o-ring to be shot on such a new car, but I guess anyhing can happen.
