1 - 1 of 1 Posts
· Registered
Shipping out of Los Angles, CA 90012 to the contiguous USA
Everything 25% OFF
Items in 1 picture do not necessarily mean that everything in the picture is part of a combo. Some items are part of a combo while while others are a la carte
*** SOLD *** RC 440 Saturated Injectors for B-series - $200
*** SOLD *** Endyn Breather Can - RUBBER GROMMET oNLY - $7.00
*** 1/2" ID Y, Reducer Couple 1/2" x 3/8", 3/8" ID Y - $5.00 per set of 2
http://home.comcast.net/~chungfrog/fs/y_1.JPG
*New*
These fittings are made by http://www.eldonjames.com:
KYNAR®: Temp. Range – 80°F to 226°F / Pressure 260 psi @ 70°F - Autoclave temp. to 285°F (140°C). Meets USP Class VI Requirements (US Pharmacopoeia).
*** Moroso Aluminum Weld-In Bings, 3/8'' NPT Fittings (2 sets) - $10.00 per set
*New*
http://home.comcast.net/~chungfrog/fs/bungs.JPG
*** Map Sensor Assembly (from a 1992 integra) - $20.00
http://home.comcast.net/~chungfrog/fs/map1.JPG
http://home.comcast.net/~chungfrog/fs/map2.JPG
*** Dorman 34.3MM plugs - Box of 7 - $7.00
http://home.comcast.net/~chungfrog/fs/dorman.JPG
*New* Plug for the back of the block when installing the Endyn Breather kit. Please check that this is the size you need. I used it on LS & GSR blocks.
*** Vtec Valve cover clamps (for spark plug wires) - $9.00
http://home.comcast.net/~chungfrog/fs/spark.JPG
*New* Included part numbers:
32763-PM3-000
32766-PR3-000
32777-PR3-010
32777-PG7-J00
*** Throttle Body Gasket - $6.00
*New* Part Number included in the following link:
http://home.comcast.net/~chung...1.JPG
*** Spark Plug tube seals (set of 4) - $7.00
http://home.comcast.net/~chungfrog/fs/seals.JPG
*New* Part#: 12342-PT2-000
*** PGFM-FI Relay (MAIN RELAY) - $20
http://home.comcast.net/~chungfrog/fs/pgmfi.JPG
*** Outlaw Engineering Throttle Body & IACV spacer - $25.00
*New*
http://home.comcast.net/~chungfrog/fs/outlaw.JPG
*** 10x42 bolts, 12mm Castle Nut, ITR Throttle cable bracket + misc
http://home.comcast.net/~chungfrog/fs/bolts1.JPG
http://home.comcast.net/~chungfrog/fs/bolts2.JPG
http://home.comcast.net/~chungfrog/fs/misc1.JPG
http://home.comcast.net/~chungfrog/fs/hoodpin.JPG
http://home.comcast.net/~chungfrog/fs/misc2.JPG
*New*
3 x 90120-SB0-003 are bolts primarily used for suspension.
1 x 90363-SF1-000 is a 12mm Castle nut. Suspension nut.
1 x 16411-P73-000 is an ITR throttle cable bracket.
3 x Used bolts - probably from a throttle body
5 x Hoodpins - set your alarm off if someone pops your hood.
+ Misc hose clamps
Everything for $15.00
*** Dist. O-ring, solenoid gasket, Climate control bulb, etc... - $10.00
*New*
Included Part #'s:
91316-PT6-003 (I forget what this is for)
30110-PA1-732 (Distributor O-ring)
36172-P08-015 (Solenoid gasket)
34354-SB0-003 (Climate Control Bulb)
Misc gasket (looks like a distributor cap gasket)
*** Thank You for looking! If you're near Downtown, LA. I'm available for pick-up, just schedule an appointment please
1 - 1 of 1 Posts
