1 - 10 of 10 Posts
Two 12 inch Alpine Type R SWR-1241D subs with MTX THUNDER Amp!!!
$500 Shipped
These subs hit hard ... very versitile with the music you can play on these. I listen to rap, rock, emo, country .. you name it, I listen to it sometimes. The box is sealed and sized for the subs. If you are just looking for a little bit of bass to complement the music, these subs may be a bit too much for you. These are for those who want a lot of bass and want it to sound good. This set-up has been great for me, never blown a fuse, never even cut out. Below are specs and pics.
Specs for the subs:
>Kevlar®-infused pulp cone
>1" Santoprene rubber surround
>dual 4-ohm, 2" voice coils
>frequency response 24-1,000 Hz
>power range 100-300 watts RMS (150 watts RMS per coil)
>peak power handling 1,000 watts
>sensitivity 87 dB
>top-mount depth 6-15/16"
>sealed box volume: 0.7-1.0 cubic feet
>ported box volume: 0.75-1.75 cubic feet
[Click on pics for larger picture]
Specs for the amp:
MTX Thunder 8302 2 Channel Amplifier
>2 Ohm Load 212 w x 2
>4 Ohm Load 120 w x 2
>Bridged 4 Ohm Load 425 watts 850 peak (What the amp would be run at when running the subs)
>THD at Rated RMS Power: < 0.1%
>Preamp Outputs: Yes
>Built-In Crossovers: HP/LP
>Bass Boost: 0-18 dB
>Frequency Response: 20-20,000 Hz
>Channel Separation: n/a
>Signal to Noise Ratio: > 110 dB
>Fuse Rating: 2 x 30 amps
Reason for sale: I purchased these a little over a year ago and now what I am at school with no car, they get no use and I would rather have the money for something else.
Shipping Info: Shipping is included in the above price. If you want to work something out where you can pick them up, I will take deduct the shipping from the price If I ship, it will be via UPS ground unless other wise requested.
just wondering, why are you selling them?
edit: nvm, i see.
would you be willing to separate? i might be interested in the amp if you will.
does it come with all the wiring?
I would rather not separate them if at all possible unless I am able to find a buyer for both. But in a few days if nothing happens that would be a real possiblity. Hit me up with an offer for the amp ...
Also, I am willing to work out some sort of trade if you have any ideas you want to throw my way ...
Wow I wish I could get this but I'm a lil short of money. I need a couple hundred more. Which is basically all of it i guess you can say. Is it still for sale? If it is I can probably buy it in a few weeks. Let me know
1 - 10 of 10 Posts
