1 - 20 of 31 Posts
This is what happens when you have the same size tire on a different width wheel.
Interesting eh???
Hold up on the responses while I check the link...
Link should work now. At least it did for me. Let me know if it still isn't comming up. Its an interesting comparison.
Link works...interesting pictures...I don't know that much about tires and tread wear to draw many conclusions from them...anyone care to elaborate a little?
yeah, I must not be an auto-x guy. I don't get it at all. Something about contact patch?
Discussion Starter · #11 ·
Well what can you guys tell from the pictures? A picture says a thousand words (sometimes more)!
Interesting...
Mounting a 205/50 tire on a 6.5" wide rim pinches the sidewall in more making the contact patch rounded where as the larger 7.0"-7.5" wide rim lets the contact patch lay flatter. Makes sense.
Discussion Starter · #15 ·
mystikallobster on Mar/09/04 said:
What exactly is it that you don't understand? Maybe we can help clarify things if you ask questions.
Dan...it depends on your tires too. Not all tires are created equal. Falken Azenis 205/50 are wider than most other 205/50 tires. I run my Dunlops for daily driving on my 15x6...and it's fine. It just depends what you're using it for. That's why I'm going to get at least a 15x7 for my Falkens on the track.
white_rice on Mar/09/04 said:
Interesting...
For what it's worth, 205/50-15 Azenis are designed to be used with 15x6.5" wheels, so that size is going to have the ideal contact patch and tire behavior.
1 - 20 of 31 Posts
