I want to switch to a dot4 brakefluid (synpower is my choice as of now), what would be the best way to drain my current brake fluid?
Should I just drain it all out of one brake bleeder screw, fill up, then bleed all four brakes?
Or should I drain it from all four brakes, then fill, then bleed all four brakes?
Draining it dry is probably going to get alot of air in it, which means lots of bleeding, any better way to do it?
Thanks in advance =)
