ok so i have my floormatts out while im doing my sounddampening install and i thought about putting them in the washing machine... is this ok to do or will they melt or get messed up. these are stock floormats
Yep, and add a scoop of Oxi-Clean in there. It will make a difference. Use the Warm/Warm cycle and make sure your washer is deep enough to fully submerge the mat.TheGSRGuy on Feb/08/06 said:Do it on a gentle cycle.
sounds like the best idea here. if it is really bad take some oxi-clean and a brush with the high preassure.fordcourier72 on Feb/08/06 said:i always wash mine at the carwash. using the high pressure soap, and then rinse with water. it works great. and yes only air dry, but i do use a wet/dry vac to get most of the water out.
