i see alot of tegs w/ their ac fan deleted and i was wondering why? for cleaness? dosn't it also cool down you engine/tranny also?
thats miss information bro. both fans work in tandem... when you turn the A/C both fans come on... the the temp switch turns on both fans come on. they are wired on two indepent circuits as sort of a fail safe, but they always work together.mindlessracing on Feb/04/06 said:the other fan only comes on with the ac is active. if you have a high horsepower motor than you should consider running it, but than you would also hava a better radiator also.on my drag car i wired up the ac fan to come on when the reg. fan comes on.
It just means you don't have A/C. If you want A/C, find out what's wrong with the compressor (either the clutch, or the entire compressor), and have it fixed with a new belt.UneaK on Feb/05/06 said:I have the belt to my AC unit clipped because the AC unit itself was making a wierd whining noise. The belt was clipped at a dealership, by a mechanic, Is this bad?
