since someone brought back the "what is a powerband?" thread for discussion, I thought this would be a good time to also bring back another related concept at the same time for you to discuss.
I recently saw this decent explanation of engine transients (enter transient in the articles search and in the search window here to get up to speed):
BTW the next "Quiz 4: Which 1 is the Fastest?" is coming in March. Look for it and participate.
If you haven't participated in one, check out the old ones linked in the thread entitled "Intense Learning" at the top of this forum. They're fun.
Something we try to teach you here with those Quizes...liverforphysics on Feb 26/04 said:Tuned engines use resonating pulses that enable an engine to have a high volumetric efficiency (VE) [TI Moderator Note: search under resonance or ram theory or read the IM article and also search under "sequential pairing" in the headers for the background to these pulses ].
These resonating pulses can only work if they have a pulse before them to follow. After an engine has been jerked down in RPM from a shift, this pulse timing is messed up.
Transient responce is the amount of delay before the pulses have timing that can be benifical to VE again.
Its like the engine getting back on its feet and ready to pull 100% again after getting knocked on its ass from the shift.
Compromises are made in flow, hp, tq all sorts of things to enable this delay to be lessened. Also, if you're using a glide (auto tranny), you will not need to sweat transient response as much as someone with at short ratio 6spd. Its about compromises.
I heard that in formula atlantic, they ended up dropping a ton of time with a header that had its tq peak 1500rpm below the lowest engine speed that the engine would ever see in the race. They dyno numbers were crappier everywhere you looked, but the car was faster around the track because it would make power after each shift with less delay. This is why we need to not see the dyno as our king, and tune deeper then numbers can quantify.
