right in a few weeks i will be taking my engine out because the clutch needs replacing and the three bolts in the top engine mount have sheared off (if anyone can shed some light on how this could happen it would be great).
while its out i will be :
changing the clutch,
replace all engine mounts,
light weight flywheel,
cam belt + tensioner
water pump.
can anyone think of anything else i should do while its out ??
All I have to say is that none of that requires you to pull the engine out. But If you are then change the gaskets/seals and flush the block. Change the oil, MTF, brake/clutch fluid. Might as well start fresh.
