Whats up members, i want to put a electric oil pressure gauge in my car, but i have no idea where to start, i have looked on here and could find nothing for the install of an electric oil pressure gauge..... will someone please provide me with the how to install an electric oil pressure gauge and what i will all need to do this.
Thanks
ill be doing this probably in less than a week, i guess ill do a DIY about it when i do, but all i can tell you is that the metal sender unit that came with the gauge need to hook up the oil pressure sender unit on the car, so look up where thats located. and from there its all the electrical wiring.
Endyn's advice
^^^^^a great tip from endyn read before you attempt it, other than that larry suggested to me back when i was doing my engine build to just use a sand which plate in-between the block and filter, since i was going to use their pluming kit.
you can find your constant 12v, accessory, & illumination wires at the fuse box Here in the T-I articles other than that you just mount your gauge into your pod run your wires up there and you're good to go
-Jose
About this Discussion
3 Participants
Ramirez428
Team Integra Forums
Full Forum Listing
