If you're blowing the fuse every time you crank, then it sounds like you have a short to ground in the fuel pump circuit.
do you know where it could be in the circuit I know my alternator is bad and I'm replacing that soon but where else would it be in the circuitIf you blow a fuse every time you crank, it sounds like you have short ground in the fuel pump circuit.
