Ok so below are my results. I have a B18b1, with crower #62403 Camshafts. My Calculated Dynamic CR using these specs came out to 8.59:1. I am guessing it is possible that I may be losing some cylinder pressure up the intake ports. If so, how can I be sure? I am planning on trying out different cam gear settings next time I hit the dyno, I am also considering the possibility of a thinner headgasket to bump the compression a little. Bottom end building is not an option right now. Any help is appreciated
Your engine summary is as follows: Bore 3.19 inches, stroke 3.50 inches, rod c-c length 5.394 inches, with a static compression ratio of 9.2 :1. Your camshaft specifications call for an inlet valve closing of 37.5 degrees ABDC (after bottom dead center).
Your chamber volume is 55.90 cc's. With this camshaft your dynamic, or effective stroke is 3.24 inches. Your dynamic compression ratio is 8.59 :1 corrected for cam timing, altitude, and rod length. Your dynamic cranking pressure, corrected for cam timing, rod length and altitude is 174.29 PSI.
