i jus got a megan racing testpipe for a 98 integra and it dindt come wit a o2 sensor plug so is it a good idea to make a plug for it meaning i hav to drill a hole??? anyone hav the same promblem with a testpipe??
as someone who uses test pipe (i really dont care if you flame me, its what i like), i will say a few things:edit*
also as mentioned above, test pipe isn't really what you would need/want. especially if it's a NA car. if you try a search, MD has posted a dyno graph several times showing that a high-flow cat provided more hp while the test pipe actualy showed a loss on a NA car...if i remember correctly.
Wow...with all that incorrect information, please refrain from posting anymore.satx-94integra on Jan/27/06 said:Quote: edit* also as mentioned above, test pipe isn't really what you would need/want. especially if it's a NA car. if you try a search, MD has posted a dyno graph several times showing that a high-flow cat provided more hp while the test pipe actualy showed a loss on a NA car...if i remember correctly.
i had test pipe installed and threw *no* CEL. i have no cat either, and i still throw no CEL
a test pipe = free flowing = small gain when compared to an 'exhaust system'. i believe MD said youll get a +2 hp gain if you use test pipe vs an exhaust system.
if you get test pipe, hollow out your cat and leave your resonator on. the sound is LOUD w/ no cat or resonator.
also consider investing in a silencer.
one last thing:
performance cats vs normal cats? both are free flowing. ALL of my mechanics and 210 performance have said the same thing. buying a 'performance' cat is a waste of money. get OEM, as all cats nowadays are free-flowing.
satx-94integra on Jan/27/06 said:i had test pipe installed and threw *no* CEL. i have no cat either, and i still throw no CEL
