1 - 18 of 18 Posts
that's a clearer pic than the articles hehe. hint hint Ross. LOL J/K dude
those look like the correct bolts.
Yeah can we change out that pic in the article to this one...gives a better view and more precise orientation of these bolts!!! Pretty please mods!!!!?????
don't forget! loosen the fill bolt before loosening the drain plug - incase the fill plug is seized.
wow, this guy is my kind of member, hes been here less than two months yet he is already posting pictures along with his questions that quite frankly are better than the ones in the article, and lets everyone know EXACTLY what he wants, no bullsh*t, i like that
FYI - if you have an aftermarket magnetic drain bolt, it will NOT be the socket type that comes stock. It's a standard 17mm just like the fill bolt.
You have the factory one tho, so, all clear. :)
I the tranny can also be filled from the breather on the top of the tranny. You need 5/8" tubing to fit snugly around the breather and you'll need to keep track of the amount of fluid added. I actually find this way to be much less messy and less frustrating.
i did the same thing, scott when my fill bolt was seized and got stripped (by me). I actually used parts of a manual cyphin, fit the tube over the breather, put a funnel at the beginning, and poured in the amount through there. Luckily, the fluid going into a sealed case created a vacuum keeping the tube sealed around the breather.
white_rice on Apr/20/04 said:
Tranny breather? Where is that located?
Awww nuts Jonathan showed us that last weekend when we replaced his bumpstops. That's on top of the tranny near the speed sensor. I heard people talking about filling through that place also.
on top of the tranny, you'll see a small brass tube with a black cap ontop of it. that's the breather.
to get really stupid and technical, it's not a breather, it's just where the fluid is put into the tranny while on the assembly line.
If it was a breahter, it wouldnt have a rubber cap on it ;-p.
If you've filled a tranny sideways, you realize that it's a pretty slow process as it can only go in so fast and is releively awkward. on the assembly line they can just put the drain bolt in, blast the correct amount of fluid in through that tube, cap it of, put in the filler, and be done in a fraction of the time it takes to do it when its changed.
1 - 18 of 18 Posts
