on my 99 the power door locks just stopped working one day. I have a viper alarm system hooked up and use it as keyless entry. That does not work and the switch in my car does not work. I swaped out the modulater in thedoor but that did nothing as well. the worst part is I can not get in my hatch because it is ran off the electric door locks. If anyone has any tips or suggestions i would appreciate it
wow this is odd, i FINALLLY solved the problem today that has been plaguing me for months with my power door locks..after i installed my alarm (in which i took the door panel off to mount the status LED) they worked intermittently, and then stopped working at all.
i used my Helms manual, and tested all of the different wires and all of that, no luck..i even bought a new door lock control unit like you did off of eBay, and that didnt work.
so today, was trying other stuff, and it hit me, maybe there is a grounding problem....sure enough, when i spliced a nice clean ground into the black wire running to the door lock control unit, they worked! i took my splice away to make sure, and it stopped again, so it was def a poor ground the whole time. my white/green wire that supplies 12V Constant to the control unit also just fell out of the molex in the door when i was playing with the molex today, so that compounded the problem. i havent hooked it all back up yet since it was gettin dark out, but i will probably just run the wire around the molex since you cant fix molexes really...
so my adivse is, check your 12V with a multimeter, and make sure you have god continuity to ground on the black wire.
in a few minutes ill post some screenshots of the pages in the helms that are REALLLLY helpful
EDIT: here you go, do all of the tests that they suggest, if you dont have a multimeter, go to raido shack and spend the 15 bucks, it is the greatest tool ever(next to the sliding compound miter saw of course, lol)
you are having door lock probelms too Cyrax? damn, G3 doorlocks are bullsh*t...anyway i hope anyone else who is having problems with them sees this thread with the pics from the helms i put up...if the stuff in those pages cant fix ur locks, nothing can because this is the book the dealer uses, as well as the best honda mechanics....
Did you have your battery terminal off for a while. If so it might be the alarm rather then the door locks. I recently drilled through the driver's side molex plug to run new speaker wires and at the same time I was relocating the battery to the trunk. Well after I finished for the day I noticed my alarm wouldn't lock the doors. I went to the guy that installed it and he told me to unplug the brain to let it reset itself and that it should do the trick. I would try this first.
