1 - 2 of 2 Posts
So I was having trouble unlocking my door.m and locking turns out the metal rod connecting to the exterior door handle and the metal rod connecting to the interior lock both got disconnected. The doors closed so it won’t open. Anyways if getting the panel off or the door open
Yikes! That's a heck of a predicament. The door panel is against dash. The bottom of the door panel is also held in by clips. I can't think of a way to remove the panel without completely destroying it. You "might" be able to put the window completely down, and attempt to operate the rod by looking down into the door from the window opening and somehow use a skinny device to pull or actuate the mechanism of the door latch.
1 - 2 of 2 Posts
