Quote: nugget61 on Oct/01/07I got an aftermarket alarm/keyless entry and lock actuators. Theres an article here that Z wrote that is really easy to follow. Just buy all of the wire harnesses that you can ( Personally I'd go aftermarket, not OEM ) and it'll make youre life a ton easier. Don't buy a crap system, youll regret it and spend more getting a nice one ( living proof ).
As for difficulty... not too bad, except for getting wires through the door. That defines a sob.
all of my parts are off a 95 teg. thus, this will be a hard task to accomplish?
this is the article nugget mentions
If you want "oem look", simply picking up the stock pieces that have the switches on the doors will tie right into the aftermarket stuff, which is MUCH eaiser an install, MUCH cheaper, and does the job with the same exact results as any oem system
