you are getting a hell of a deal, if you don't do it. send him my way. basicly its a good $1000 for a b18c/b16a port and polish, another $300 for a valve job, about $600 for cams, springs, retainers. so that adds up to be around $2000 for only a few hosepower. keeping in mind the more boost you are running the more that headwork will help. so if you are running alot of boost, you can get quite a bit of power from it. but in low boost the difference will be nominal. same goes with intake manifolds. people in low boost tend to lose around 15-20 whp from upgrading stock intake manifold to a j/g or rev hard. but when you up the boost significantly, the manifolds large plenum and short runners become benificail. thus increasing output.
I am in no way saying the head will not give you power, because it should as long as it was done correctly, and it should make a good amount more, but cost wise,to get it done yourself its not the first thing you should be thinking of. the whole cost thing is refering to people who do it thereself, you would be getting it for cheap or free.
