1 - 14 of 14 Posts
i just dropped my car 2.5 " in the rear and 2.25 in the front, i got camber kits for the front but i heard thats lcas adjust camber in the rear is this true? if so will lcas make it so i dont have to buy rear camber kits?
Banned
Anyone know of there was a big handling difference though? I doubt it would be too noticeable like a rear sway bar/new coilovers, but just thinking......
Yes, the rear LCAs, if you go with aftermarket such as Skunk2, WILL pull in your camber a little. When I lowered my car, I didn't need the rear camber kit, but installed it anyways.
Either way, get your alignment checked after lowering, if it's out, you'll need the camber kit.
cool im def gettin the front kit cuz im sure after a 2.25 " drop will affect camber and i figure if the fronts out the rear will be too (2.5") drop so jus checkin all this out b4 i buy either
Adding LCA's that are after market aluminium ones are part of a full lighting "package of the whole car. Just doing the LCA's wont do ****..........er......anything.
Banned
Am I the only one that thinks these drops will look WEIRD? Seems like most people drop the front MORE than the rear b/c of the diff in size of wheel well openings.
When you drop them the same amt, it looks like the front is higher when it isn't.
I know there are SOME LCAs that help accomodate for camber in low cars (they're shorter).
nope def not heres a pic i dont see a truck in here anywhere lol
Discussion Starter · #14 ·
im def gettin the front kit and ill prolly get the rear as well and of course the align.
1 - 14 of 14 Posts
