I was just wondering... What is the lowest price that anyone has pieced together a turbo setup on a Teg for? How about an average price?
I just want a simple low cost turbo. I'm sick of being slow because of this elevation (5820ft). I only need to run about 2 psi to make up for the elevation, so I'll probably go for about 4. I'm not very into drag racing, so I'm not going to spend a lot of money on power adders. I just want to have a long lasting daily driver and not get killed on the straight sections of a track or autocross.
So, I'm thinking about piecing together a cheap basic turbo setup. Probably no intercooler, and a mild, if any, fuel system upgrade (just enough so I don't run lean at 4 psi). I would likely get a used, but in good condition, compressor and an exhaust manifold to fit it. That's where I immediately forsee problems... What FI cars come with compressors that would work well on a Teg? And how do I know what exhaust manifolds it will work with? Will it simply work as long as they bolt up, or are there clearance issues as well? Anything else I need to consider? Thanks!
