i've been tossing around the idea of a trans cooler for my ITR for a while now. I notice the trans getting pretty hot when i track the car or when i take it out for a cruise through the mountains. I change the fluid frequently but the heat really bothers me. It gets very warm too hot to touch for more than a second at a time.
I dont think its causing any damage but i am very overprotective of the engine and trans. So here is what i have come up with...
I'll tap the drain plug or i will buy a fiting with a barb that will screw into the drain plug hole. that will run to an electric 12v fluid pump. The pump will push the fluid through a small trans cooler and the return will feed back through a barb fitting in stalled in the filler hole on the trans.
the only issue i'm having is finding a pump for a reasonable price that will fit my application. I'm doing some more searching as i type this out so i'm gonna see what i can come up with.
If anyone has a setup like this or any input on my ideas i would love to hear them.
