You can do either. A grinder or even dremel with the right wheel can grind the bracket down or you can get a 3mm spacer and be done.I just swapped wheels from te37 15x7 to stock LS mesh wheels and the caliper brackets are hitting every so slightly on both wheels... Is this normal? should I file away some of the bracket or just add a 1-2mm spacer/washer?
Exactly. The bleeder screw has to be at the highest point on the caliper meaning you have to swivel it so the screw is facing up.so jeff what your saying is that they should bolt right up only trouble is bleeding it the first time around holding it in the air with fluid in and press on the piston to push out air?
Make sure your dust shield is not touching the rotor. I just had this issue and this was the solution.Mine are installed and I also have a scratchy sound from drivers side every time I lightly press the brakes that goes away when I press the brakes harder. It's kind of annoying, what is that?
