21 - 40 of 828 Posts
I was just *****ing about brake fade the other day, and started pricing out "big brake" upgrades.
In short... I love this thread so much right now. Thank you!
-Brian
Basically. Its just more responsive. When I have a car full of people it still feels great.
Different pad brand/material will change the feel and modulation more than a caliper change.
Depends on the caliper change. ITR (accord) calipers have the same piston size as stock so you're right on this setup.
Yeah im not saying that changing the caliper wont change the feel, but the pad has alot to do with the feel as well. Just thought id add to that before other members start expressing their opinions on this setup. Someone might feel this setup sucks, but might be running cheap, quiet no dust pads. Pads are just pary of the whole package.
Agreeed. From my experience - running no dust pads - the larger pads with worse compound have similar stopping capability to stock sized pads with better compounds.
Discussion Starter #31
Well HPS and EBC reds are supposed to be very similar. I put stainless lines in to so that may have helped the pedal feel.
I mainly did this for the bigger rotors to handle the heat from stopping from 130+ pulls.
And I needed a full brake change, as my fronts are warped and back rotors have grooves.
I was thinking EBC sport rotors with EBC green pads, but that's $450 for all 4.
Hmm, worth a thought of change man. Thanks.
What a great thread :D:D:D !! But seriously thought, gotta love how Honda owners always find great ways to mod\improve using other model, OEM, quality parts.
The SS lines should be here by the end of the week.
I have not tried other wheels but I have been told LS meshes clear and 15”x6.5 Rota slips do not. Please chime in if you have experience. My 16” GT3’s are very close.
Does anyone know if there's any size difference between the legend & ITR calipers, for clearance issues with the rota slips?
Discussion Starter #37
Theres a thread here with info on legend calipers. But i bet you could use legend calipers with these rotors to
Ok so I have a couple of questions.
1. Do you have to machine the V6 Accord caliper brackets to make them work, or are they direct bolt on?
2. With a V6 Accord caliper which rotor should be used: Prelude or Cooper (or are they the same minus redrilling the Prelude)?
Just curious because I purchased some V6 Accord calipers at $20 for the pair, so since my rotors are warped those are the only things I have left to buy...
On a side note, does anyone know what banjo fittings are used for the calipers and what size fitting is used to mount to the hard line. I am an aircraft mechanic, and our hydraulic shop will press on the fittings for me since I have about 40ft of SS braided line.
Thanks,
Joel
1. No. Not with cooper rotors.
2. Use cooper rotors.
So, if this works with the Type R calipers, and the Spoon calipers bolt right up to the Type R, will these rotors allow me to run the Spoon calipers on 4x100??
