Feel free to skip to "Questions" if you don't want to read the whole thing.
Background: After a hit-and-run July 3 2003 I decided to go JDM for the repairs. I've done everything out of pocket because I don't want to risk raising my insurance rates (yes, even for a hit-and-run claim). I used what I had in savings and some help from "the folks" to get the parts. The car sat for a couple months while I saved for the labor to get the frame fixed and the rad support welded on. I finally got the car driveable again September 2003. Now, over Spring Break my future father-in-law is going to help me paint it.
Condition: I got the parts used from PasswordJDM.com. They are definitely used. The hood and fenders have many many dents and scratches. The bumper and lip have some scratches that may need some type of plastic filler, it's iffy. I also have an ITR wing, stock side skirts, extra 4dr rear handles, scratches on rear bumper, and emblem holes in the trunk that I want to fix/paint. All parts can be removed to repair/paint, so no masking will be required.
Parts: This is a link to a breakdown of all of the parts and what I *think* they will require.
My experience: Not much. The past couple of months I've been rounding up little projects to practice. I've painted a computer, model car, my door trim, strut bar, brake calipers, grille of my bumper, etc., etc. I did all of that with spray paint, but my results have been pretty good. I also have experience wet-sanding a car way back in high school.
My father-in-law's experience: He is a self-employed farmer (of sorts). He runs a fleet of semi-truck sized forklift sorta farm equipment things called "squeezes". Basically they are forklifts on the back of semi cabs. He rebuilds/maintains/paints them himself. He has all necessary tools (hvlp guns and etc.) I'm just not sure if he's ever done small automotive projects.
Location: He lives in Oregon. I live in Colorado. This presents a couple of problems. First, I need to have all my ducks in a row before I make the (24 hr.) trip out there, ie. I need to have all my supplies lined up. Secondly and most importantly, the paint isn't going to have more than 3 or 4 days to cure before the drive back to Colorado. You can see my concern.
Questions: Being a novice, and wanting to be overly prepared to do a good job leaves me with a few questions that I hope some of you professionals will be able to help me with...
-Is it necessary for me to repaint the whole trunk lid and rear bumper to fix some scratches/emblem holes?
-I thought about covering the front in trash bags for the drive home. But then I read that curing under the bags/car cover/wax could cause the paint to bubble. Any thoughts on this? Other options I have to avoid rock chips?
-Do I need a paint softener or special primer for the ABS parts? Product suggestions?
-I'm planning on taking the JDM parts down to the metal/plastic before primering. Is this a good idea?
-Plastic filler? Thoughts or product suggestions?
-I'm guessing Bondo is the correct approach to fixing dents. Should I be looking in another direction?
-Are there other preparatory steps/chemicals that I haven't mentioned (especially for the plastic parts)?
-How much primer, paint, and clear coat am I going to need? Are there online sources for these supplies?
Thanks to all of you who took the time to read this whole thing. And an extra special thanks in advance to any of you who can offer me some help. Your comments will be greatly valued.
-Nate
-Nate
