You want to get those suckers off easy - buy the vamplier screw removal pliers and it will be off quick- Then go buy an m5x .8 10 or 12mm bolt from home depo and you can easily get it off with an 8mm socket even after using blue loctite!!!!
does the extra weight from the head of the bolt will cause balance problem in the distributor rotor over time?
the bolt head isnt much bigger than the screw but will be easier to remove - I will let you know the next time I change it but I doubt it will cause an issue- its tight so no or little force is exerted and the dizzie shaft is pretty stout
