Ok guys I need you help please. After getting off work today a few blocks from work my car started bogging. I was going around 25 mph, all of a sudden my rpms dropped and loss of power. I had to pull over right a way, and my car died. What the hell.!! I then tryed to start in up but no go. engine would start but ran real slugish. rpms would not pass 1000 rpms. called my friend Ron and suggested it may be the coil of ignitor. we tested the plug wire for spark by pulling it out and grounding it on the head. no spark. With limited tools and on the side of the road we went to purchase a coil and installed it. so I went to crank the engine and nothing, same problem as before. this time now the engine won't turn over. seem like the starter just spins. puzzled. I said what the hell, lets see if the rotor spins at all. we left the cap off to see what would happen. found out that when the engine cranks the rotors does not. looking at the other end the belts seem to spin. WTF!! Can that be a bad distributor.
Has any one ever experienced this issue.If not can anyone make an educated guess.
I would appreciate it. sorry if its to lenghty of a post.
I'll be at work tomorrow so I'll check back with you later in the day. Thanks T-I.
