After reading thee nitrous article and hearing about the big power gains a direct plate gives for a gsr. I was wondering exactely what should i do to my car to make it reliable and is this kit more dangerous than others? Also, how much would a 75 shot increase performance. Thank you
Ugh risky. By the way, it will blow your warranty if you have one, whereas with the nitrous ported into the intake you can still remove without the factory ( well a technician ) knowing the difference. Id go with a kit from NOS or Zex. They are very trustworthy systems. Id only suggest going with a plate if you have a well built block that will handle it. The kits can mount on to almost stock honda engines as long as they run 75 shot or less.
