What is the Diameter of the PS return hose ?
OEM Part # 53731-804-J50
Because I want to flush it completely - looking to connect a tube via a Splicer - what size should I get?
Discussion Starter #2
Also removing the return hose - will it end up in leaking due to hardened rubber?
Similar problems. Yes, the old hardened rubber hose will leak and, or the pump will cavitate (and make more noise) from sucking in air. If you have a 98-01, you can still replace the hose, but if you're like me with a 94-97, you've got to roll the dice that the Gen3.5 will fit on a Gen3, seal properly, and not get tore up by the PS belt.
IF the hose is for sure getting replaced, you can cut through a middle section and measure the inside diameter there (SAE: between 7/16 & 11/16). Measuring the stretched connection ends will give you the wrong ID. The OD is 20mm FWIW.
