My dash's brake light stays on after I put the brake down. Has anyone else run into this problem? The Integra doesn't have a brake lining wear indicator, does it?
You probably have low brake fluid. Mine did the same thing and the dealership fixed it for free.
Thanks, I'll check the brake fluid.
Also, I tried searching. Go to search and type in "brake light" (searching forum body) and the only relavent post on the first page of results is this post :)
Yes, try the brake fluid idea. Mine did that too, stayed on when I put the e-brake down. Even though I opened the lid to my brake fluid and it was filled to the top, I added more anyway just because and it fixed the problem. You should be ok.
Thanks, 5-Lug. I'll probably flush the brake and clutch fluid while I'm at it--brake fluid, at 67K, is starting to look like French Roast.
