So, I've just been enjoying the hell out of this car, I've put about 3400 miles on it since i got it inspected back in May. I just recently took the car in for some very VERY bad tire wear on the drivers side. The inner part of the tire had metal hanging out. My shop said the camber on the front tires is at -1.9 and -1.7 which is causing the wear. Now, some of this wear might have occurred also prior to the new inner tie rod. The passenger side front tire has a similar wear pattern, but its not nearly as bad as the driver side. So, I bought a new tire so I can continue driving the car safely, but it's making me wonder if I should look into grabbing a set of adjustable upper control arms again. Or maybe cheaper tires, the kick to the gut with these tires is they had a 500 tread rating on them and there is only about 14K miles in total on the tires. The backs seem to be wearing just fine. My suspension is OEM ITR coils on KYB struts, I never thought that the ITR suspension would throw the camber off that badly, so I just went with stock upper control arms for the car.
oooops, forgot the obligatory picture of the car.
