721 - 740 of 771 Posts
Discussion Starter #721
So, this past weekend and probably the next few weekends ahead, i'm going to have little to no time to work on the car. This is terrible for 2 reasons - 1, i wont have time to diagnose the many electrical issues the car now has and still have time for body work and paint. 2 - i'm getting close the the cut off point for painting this car this year i think. So all of the many, MANY electrical issues the car now has will have to be dealt with over the winter after body work and hopefully paint. Then maybe the car can come out and play next year. I'm hoping its something "simple" and common to all of the issues and i can fix it quickly. The one that upsets me the most is the closed loop issue still persisting. I'll have to do some research, and probably back through my own thread to refresh my memory on what triggers the car to go from open loop to closed loop.
Discussion Starter #722
Ugh, so...the car has decided to change my plans for me. After doing some exploratory cutting and assessing the situation, i think primer and paint is completely out of the realm of possibilities before cooler temps hit. I really was not expecting the rust to be so bad on this side of the car, its 10x worse than the other side was. Its going to take me a while to get this cleaned up and repaired properly, or at least repaired to a point that i am comfortable with it. This side had the quarter replaced once before when my car got backed into and they crunch the area just above the tail light and buckled the side of the panel. I'm wondering if they didint clean everything 100% before they did the repair. I mean, it happened probably 14 years ago, so who knows. Either way, i got my hands full with this side.
Not really looking forward to this, the passenger side was so "easy" compared to this. So, new plans....get the metal work done and repaired before it gets too cold, throw some quick aerosol paint on the metal so it doesnt start to rust over the winter. When i can over the winter - put the rest of the interior back together, replace the oil pan in the motor, finishing wiring up my kill switches, install the ITR cat back, re-install the alarm, finish my s2000 retrofit, and finish (hopefully) diagnosing the issue with the open loop error. I'm sure there are a few other smaller items i'm forgetting, but those are the main ones i can think of at the moment. Then when weather permits next year, get the car epoxied, body fillered, primered and painted. I'll have enough vacation time built up at that point, i think i'll just take a week off of work and get the paint work done then. I guess the only good thing is i got all but one of my electrical issues fixed, so thats progress, right?
bummer but at least you can handle it.
  • Like
Reactions: danteisme
Discussion Starter #725
Small, but neat updated. I did some much needed cleaning in the garage this weekend so i have room to work, so no additional work on the car. BUT, i did clear up some space because someone messaged me from one of my craigslist ads. they wanted me tan cloth seat set i had from the car. it was taking up a lot of space. The catch was, the guy didnt have any cash but wanted to trade instead. He sent me some pics of various integra things he had and said if i delivered the seats to him he would make the trade in my benefit. it was only 20 minutes down the road,so i figured why not. So, i straight up traded a tan cloth sedan seat set for this -
Came with the throttle body and most of the sensors. Not sure if i will actually put it on the car or not, but it takes up way less space than the seats.
Discussion Starter #726
So, still cutting away bad metal and prepping areas for good metal. Nothing really worth showing, but i am still making progress here and there with this rust repair in this quarter. I did finish another side project though. I finished my leather restoration (for the front seats so far, still need to finish the back). This is the seat set that i swapped seat skins from a passenger to the driver's side for my repair. The fitment isnt 100% due to how the seat backs are cut from driver's side to passenger side to clear the hinge brackets, but this is close enough for me, for now.
Passenger side redone
Driver's side redone
is it just lighting that makes that first one look white?
Looks like a lot of work, but will be worth it in the end. I just picked up a Integra shell, started to piece it back to together.
Discussion Starter #731
I feel like i'm on the downhill side of this finally. Body work aside, which i dont mind at all compared to tracking down electrical issues, a few odds and ends and paint and i'm set.
Discussion Starter #732
So, i realized that i will have too many battery connections for various items in my car. JDM fog lights, HID relay harness, stereo amplifier, and i believe one more that i cant recall exactly what it was at the moment. I had a similar issue with my truck with the various ditch lights, led bars and such. I made this (excuse the unkept wires, this was still in process).
I have another aux fuse block, much smaller than this one. I'm thinking i might want to incorporate one on the teg. I'm having a hard time determine where would be a good place in the engine bay to place one of these. Obviously, closer to the battery the better. Thoughts?
for sure. When I've had to do stuff in the winter I've setup an electric heater and my halogen work light in the garage 20 minutes or so before I need to work to warm it up a bit. The light puts out almost as much heat as the space heater...then last time they tripped the garage breaker together. Doh!
Discussion Starter #736
I have to kerosene heaters in my garage that actually make it pretty toasty. i did get to work a couple hours here and there, but my main issue lately is timing. Both kids go down for a nap, i go out and get the heaters going so that in like 20 minutes the garage will be warm and i can try and get some stuff done. Just as I'm heading out, the baby wakes up wanting to eat. My wife is awesome, and she'll usually take her so i can get something done. But lately, when the baby wakes up, she wakes my son up, and its all over after that. So i go outside and shut the heaters off so i don't burn down the garage and i shut off all the lights, and then go back in the house and play with matchbox cars with they boy....so its not all bad lol.
Mine are about to turn 3 and 5, I fully understand.
  • Like
Discussion Starter #740
Alright, lets get this show on the road and get as much non-body work stuff done as possible.
Finished up some wiring for a courtesy light in front of the cup holders in the center console.
Swapped out my DB seat rails for some DC rails. Well, on the passenger side I did. For some reason, I have 2 sets of passenger DC rails. Have to track down the driver's side so my 6 foot tall frame gets a little more clearance between my knees and the steering column.
Picked this up on the cheap as some extra insurance in case my electrical issues don't go away. Replaced the cabin harness, may as well have the extra engine harness just in case.
And my S2000 retrofit in a box. Hopefully I will start figuring out the mounting points on the bracket, then it will be all re-assembly after that.
