Back with problems on my 96 LS. Can someone tell me what's up with the D4 light blinking when I'm trying to crank the car? Also would that keep the car from cranking?
I would not be surprise if the PGM-FI main relay is the culprit.
You need to pull the codes out that is stored onto the ECU first and post them up. Make sure you have a scanner that can scan not only engine codes also transmission codes.
