1 - 13 of 13 Posts
Hi I just picked up a 95 RS sedan is has a misfire in cyl 3 pulled the plug and is black with looks like soot on the plug. I have changed the cap and rotor help needed i'm at a lost on what it can be.
Discussion Starter #4
So I swapped 3&4 injectors and still have a misfire on cylinder 3 I even swapped plugs and wires with cylinder 2. Now I'm thinking maybe a head problem
Compression test, pull #3 sparkplug and ground it a to make sure it's a white spark not orange. And see what the pressures are on all 4. Check your auto parts stores and see if they'll loan the comp. Tester.
GL and keep us informed what you find.
Honda Mike
Discussion Starter #6
Honda Mike
will do
Discussion Starter #7
So I pulled my valve cover and notice that my timing looked like this (refer to pic)
105520
Pic is way too small to make out anything. What exactly are you questioning about your cam timing? Additionally, we won't be able to give feedback until we know if you've put the engine at TDC, and then review your timing marks/alignment
Discussion Starter #9
both cams are off to the right and the engine appears to be at TDC
What do you mean "appears"?
Verify it. If your cam timing was that off, it wouldn't start. Hell, if it were that off and you attempted to start it, you'd have every valve bent. What steps have you taken to verify TDC?
Discussion Starter #11
Used a long screwdriver in cylinder one. Couldn’t check the timing marks on the bottom end due to not having time before leaving for work
You need to verify TDC of cyl #1, on the crank pulley
Discussion Starter #13
So I pulled the head off and found a burned valve on cylinder 3. No better time than now to build the head or buy a GSR head and build that
1 - 13 of 13 Posts
