Could you use the cruise control button as a fuel cutoff switch?
Not if you wire it always on.TheGSRGuy on Oct/07/07 said:You'll obviously lose your cruise control system if you do that.
my thoughts exactlyB18Ch1ck on Oct/07/07 said:yes but it's still an extremely obvious one.
Me too -- might be tight, but not wise.jameelrose on Oct/07/07 said:Quote: B18Ch1ck on Oct/07/07yes but it's still an extremely obvious one.
my thoughts exactly
dont say where you're going to put it... anyone can be on this site manmywhiteteg06 on Oct/07/07 said:Thanks for the input. yeah it is pretty obvious. i thought of fabrication a mount for a fuel cutoff switch under the shift boot. its hidden. all you do is press through the boot to arm the fuel pump.
89teg_mike on Oct/17/07 said:Do you guys have a multiwire CC botton like the g1??
Could someone PM me which wires I have to tap into to make a circuit??
I'm not too sure about relays, so I'm not sure what you guys mean when you say use a relay.
thanks
mike
