What setup?
> Turbo
What for?
> Quick Street Car, Weekend racer (auto x and HPDE)
Ok heres the skinny:
Drive train:
ODBII 2000 B18B1 with 47,000 miles (have)
GSR Trans w/LSD and LS 5th gear (have not)
Upgraded Axles
Internals:
Stock LS pistons
Stock LS rods
Stock LS crank
ARP Heads Studs (have not)
Turbo Cams (not sure which brand yet)
Springs and retainers (to match the cams)
Stock valves
Block guard (have not)
GSR Water pump (have not}
Turbo Stuff:
GT3251 turbo (have)
Log manifold with centered WG position (not sure of brand but I have it)
38mm Tial Wastegate (have not)
Tial BOV (have not)
Garret Intercooler (have)
Charge piping (have)
Oil Lines (have not)
2.5" downpipe
Management:
Greddy Type S Profec Boost Controller (have)
Turbo Timer (have....forget the brand though)
Hondata S300 or Neptune (help me decide)
RC 750 injectors
Walbro 255lb Fuel pump
Stock dizzy
Stock fuel rail
Goals
I am looking for whp in the 275-300ish range
I know the turbo meets my needs as far as boost threshold and lag through discussions with TheShodan.
So my questions are:
1) What are the best quality oil lines on the market?
2) IS the S300 worth the extra cash?
3) Would a quaife LSD be sufficient or would that have problems holding up to the power I will be putting down?
4) If the answer to 3 is no then should I get the OEM LSD instead?
5) Are my goals realistic given the setup I listed?
6) Is any of my setup overkill?
> Turbo
What for?
Drive train:
Upgraded Axles
Internals:
Stock LS pistons
Stock LS rods
Stock LS crank
Stock valves
Turbo Stuff:
GT3251 turbo (have)
Tial BOV (have not)
2.5" downpipe
Management:
RC 750 injectors
Stock dizzy
Stock fuel rail
Goals
