1 - 12 of 12 Posts
the motorcycle racing crowd and domestic hot rodders have a leg up on us import hot rodders when it comes to this sort of stuff...more reading and research is needed to apply it to my block. A 2-5% gain on a 180-200 whp motor is on the order of 9-10 whp which is nothing to scoff at. It cuts down on windage losses but also reduces blow-by and helps get you that nice ring seal. You don't want too much crankcase vacuum or it will literally suck the oil out of the combustion chamber and the valve seals...not nice... you have to monitor the crankcase and IM vacuum pressures constantly.
Moroso Crankcase Vacuum Pump
Originally posted on [url="http://www.speeddemonmotorsports.com/Tech/articles/vacuumpump.html" said:
http://www.speeddemonmotorsports.com/Tech[/url]]
Why a vacuum pump?
A vacuum pump will create a lower pressure zone relative to atmospheric pressure through continuous evacuation of air (since the system isn't sealed perfectly. Why would you want this? A crankcase vacuum reduces internal motor losses since the pistons have less to "work" against, improves ring seal, and improves oil control. on a stock car the PCV generally does the same thing - though it will not function very well in high load situations, and allows oil to get into the intake/cylinder heads. With an electric vacuum pump we can create the same depression, but over a wide variety of operating conditions, and without introduction oil into our engine induction system!
Tired of oil getting into your intake/engine through the PCV? Have a few oil or oil consumption issues that are driving you crazy? You might consider an electric vacuum pump
Vacuum pump - what?
You may or may not have heard of the concept of running a crankcase evac system. Generally there are three ways that you can do this.
Header/collector aspiration vacuum:
You have probably seen something like this before on a rail dragster. This consists of 2 tubes which fit into the header collectors at a 90 degree angle to the exhaust stream. The velocity/inertia of the exhaust gas will actually pull out gas through the tubes, which are connected to the crankcase (often through the valve-covers). This technique works well on open headered cars, but as ad backpressure (exhaust) the effeciency drops dramatically
Belt-drive vacuum pumps:
These systems use a vacuum pump which is powered through the engines belt system. This is most commonly used in dry-sump oiling systems. This allows for a great amount of vacuum to be generated (enough to maintain vacuum on even the largest motors). It requires custom bracketry and belt re-routing on a production sytle setup though.
Electric vacuum pumps:
These are by far the easiest to setup on a street vehicle. The can be mounted virtually anywhere, and only require a power, ground, and connectiont to the crank-case to operate.
Quote: Originally posted on http://www.competitionplus.com
Vacuum pumps are fast making a statement in drag racing, and with good reason. There's power in oiling systems. That's an obvious statement, given the fact that there's dozens of products on the market to control oil, from pans to scrapers, and everything in between. In the search for every exclusive ounce of horsepower, racers have sometimes gone to elaborate or unconventional means to accomplish oil control.
Alcohol racers are really enjoying using a vacuum pump. After one run, this is how much water, or moisture we pulled out of the drain can. Imagine this ending up in your oil.
The elimination of pressure in a crankcase has long been sought after. With parts swinging around and pistons going up and down, there's no possible way you can expect to make any power if the crankcase is plugged up. The engine has got to breath. Years ago people tried running hoses from the intake manifold down to the engine in an attempt to keep the crankcase under vacuum. one main benefit of vacuum is increased ring seal, which makes power because during the intake stroke, the combustion chamber is in vacuum trying to suck fuel out of the manifold. But it can also literally suck oil up past the rings. Keeping your crankcase under vacuum alleviates some of that. The problem with manifold vacuum, other than sometimes oil contamination with the fuel mixture, was that you only had vacuum at idle. Wide open at the end of the track, where you needed the power, there was little or no vacuum available. Enter the Vac-U-Pan system, which plumbed hoses from the header collector to the valve covers in an attempt to utilize exhaust pulses to create vacuum at the other end of the track. Truth of the matter though, is that they provide very little vacuum, even at best.
The next step in the evolution was the air evacuation pump from new car, which would suck vacuum. With that pump, the faster the engine spins, the more vacuum it produces. The people at Moroso, being the innovators that they are, knew that the OEM style pumps had their downfalls. For one, they didn't last. After all, they weren't designed for the rpm we were spinning them at. And two, they weren't rebuildable. Which meant that when they went bad, they became scrap metal. Moroso's fix was simple. Get out a clean sheet of paper and design one from scratch, which concluded with the manufacturing of their line of 3 and 4 vane Vacuum Pumps.
Moroso's Scott Hall explained the simplicity of their design and said, "There's very little moving parts inside this pump. We designed it that way so that it's relatively trouble-free."
Scott Hall, the sales engineer responsible with the design at Moroso says, "The three vane pump was our first piece and it works well with wet sump motors because it has more swept volume than the four vane, however, we added another vane to help the timing issue internally and we like to use that pump on motors using dry sump oil systems because it will also pull more vacuum". Hall does recommend you monitor the vacuum with either a gauge on your dash or one plumbed into a valve cover. "You don't want to pull more than around 14-15 inches of vacuum because than you're literally suck the oil out from the piston pins and valve guides, which can have dramatic consequences."
The nice part of their unit is the simplicity of it. Four allen head screws on the front of it and it comes right apart in your hand. From there it can be cleaned or rebuilt. The actual vanes are made of graphite for sealing purposes and upon first startup they tend to scrape and wear off until they're seated in. Hall recommends that after the first five minutes of running time, you take carb cleaner and spray it directly into the inlet. This will clean out any break in material that might be get caught in the vanes. "You could disassemble the pump and clean it out", says Hall, "but we've found that spraying cleaner into the inlet seems to work just as well."
Not having your crankshaft slapping through puddles of oil is the basis for most all oil system products today. Oil control is the key and dry sump systems, where the oil is in storage in a separate tank and fed to the motor by means of an external oil pump, is the ultimate for power and the reason you'll see them on most engines that demand every bit of power that can be squeezed from them. But in some cars where space is problem or maybe even finances dictate a wet sump system, running a vacuum pump in addition to any carefully designed oil pan devices will give you the most benefit you can derive from your combination.
There is one inlet and one outlet port built into the aluminum housing. While there is no pressure on either line, we still used #12 AN fittings and hose to plumb the pump.
As I said earlier, the last thing you want is the crank running through oil and here's a quick tip to check that on any engine using a deep, wet sump pan. First, know the height that the crank at its lowest part in the oil pan. Next with the oil pan on the bench, take quart cans of water, fluid, whatever, and fill the pan up to that point or slightly below it. However many quarts you counted is all the oil that you should put in the motor. Naturally, add one quart that's usually held up in the filter and if you'd like, maybe an extra half for oil stored throughout the block's oil passages.
Are there any downfalls to a vacuum pump? Not really, only if you count a slight loss in oil pressure because the vacuum is trying to pull oil out from the bearings. "This can easily be cured with an external pump, but without one", says Hall, "it's still not a problem because really what you want is oil flow, not so much oil pressure. If you could, a better gauge would be an oil flow gauge, because it would tell you that you have enough volume going to all the right places."
Another benefit to a vacuum pump is the ability to run low-tension oil rings. Ring drag is a horsepower killer. But with low tension rings, the possibility of the piston sucking oil out of the crankcase is amplified somewhat. By utilizing the vacuum pump to keep the crankcase under vacuum, that problem is rectified by closer balancing the pressure, or lack of, above and below the piston rings.
Those of you that run alcohol as a fuel, (not through your bodies), can attest to the nasty "mayonnaise" that's noticeable in your valve covers, especially on a cool day. This is due to the cooler running of alcohol that will literally suck the moisture out of the air, and mix it with the oil. While it's not a big problem, some have noted that more frequent oil changes are necessary with an alcohol fed fuel system. The vacuum pump will suck all that moisture right out. on a cool day, if you drain the dump tank hooked up to pump, it'll fill a spray can top full with water or moisture. Without it, think of making numerous runs while this moisture drains down and mixes with the oil. Easily you can see the problem.
The mandrel kit available from Moroso for either a small or big block Chevy is a quality part. It comes complete with pulleys for either a standard v-belt or a toothed belt.
The Moroso pump comes complete with an aluminum adjustment bracket that bolts to the back of the pump. But other than that, some type of fabrication is necessary to mount it. "Most guys bolt it right to their motor plate if they have one", Hall says, "but to make dedicated bracket that would fit everyone's application would be almost impossible. Plus we figured that most people who buy one would have some kind of fabrication skills anyway and it'd be better for them to mount it where ever they could".
Another must have for this is Moroso's Part #63845, which is a drive mandrel for a small block Chevy, while part #63844 fits the big block. It comes complete with spacers and pulleys to drive the pump off the crankshaft. We opted to run a toothed belt rather than a v-belt because it requires less tension on the belt. With a v-belt, it's necessary to keep belt tension so that it doesn't slip, and having the pulley driven some 3 or 4 inches off the end of the crank could cause some flex in the mandrel. We also decided to run steel braided line, but it can be plumbed with oil resistant #12 line as well, as there is no pressure, obviously, on the hose or fittings.
"The ultimate from an engineering standpoint", says Hall, "is to run a dry sump, and I recommend it where ever I can, but regardless everyone should be running a vacuum pump. From a horsepower standpoint, you should see 2-5% increase, and based on the cost of the unit, that's a cheap way to pick it up". Another very good reason for running a vacuum pump.
more reading for you serious racers who are interested in getting an edge....
http://www.rehermorrison.com/techTalk
http://www.nhra.com/
http://www.noc.co.uk/technical/commando/breather.html
VERY intriguing....when i get my turbo setup installed i'll definitely attempt a CVP system.
Discussion Starter #5
yes, this falls under the hp gain category of improving mechanical efficiency (instead of volumetric and thermodynamic efficiencies)...of which underpulleys, electric water pumps, synthetic lubricants, and engine internals weight reduction also fall under.
This is a feasible alternative to cutting windage losses instead of going to a dry sump oil system which carries a much smaller crankcase/oil pan equivalent replacement and a second oil pump to circulate the reduced volume of oil.
Here's a Moroso dry sump system:
that pan is soooo sexy. seriously!
Discussion Starter #7
yeah the dry sump pan for tegs was first shown at SEMA 2001. I thought about it but it's a royal pain running a second oil pump and noisy as hell for a daily commuter like mine. The crankcase pump is small and very easy to set up. The problem will be to lower the vacuum enough to see some gains but not too much to cause oil starvation at the valves and rings. The pain will be setting up the vacuum gauges and monitoring them.
Yet I am sure that if you took the time to do so then you would be a...no more, no less....a hero.
Talk about one helluva contribution. And it seems like no small thing either. Crankcase pressure never occured to me until about a year ago, but I never gave it any thought. I didn't see the difference between a crank swingin' through a crankcase with a high pressure or a crank swingin' through a crankcase in a vacuum.
In my physics book there was a picture of some bigass V8 with a pump and hoses that ran through the bottom end of the block. I figured it was some kind of oil pumping setup. I dunno, the hoses were equally bigass.
if you wanted to be really tricky you could wire up a pressure sensor and wire that to a relay on the pump and control the pressure.
there are a couple companies who make vacuum relife valves for the crank case vacuum system this valve bolts into the cam cover and allows you to set the maximum vacuum to how much you want it to go to the maximum is 15 inches of vacuum but to be safe i believe that 12 inches of vacuum is a good figure
http://www.moroso.com/catalog/categorydisplay.asp?CatCode=13311
there are a couple other companies who make them at a more reasonable price.
1 - 12 of 12 Posts
