Is the 2-pin electrical connector to lock ignition timing?
Yes it’s a 2 pin connector that goes to ECU that jumps it so the computer isn’t fighting back. When doing this shouldn’t the CEL come on?Is the 2-pin electrical connector to lock ignition timing?
Yup seems like that it should be on, when the connector is shorted. And I believe the car must be at idle, warmed up in order to set timing correctly.NOTE: The Malfunction Indicator Lamp (MlL) will stay on after the engine is started if the SCS short connector is connected
