Recently reinstalled dash board, I thought had everything hooked back up however now car cranks but will not start.
Fuel pump is not coming on when key has been turned on and main relay is not clicking either. Lights on instrument panel all come on. CEL came on but oddly scanner cannot make a connection.
Which wires if left unplugged might cause this situation? main relay and everyrhing worked fine before removing dash.
Having similar issue pump not engaging but cranks no start. I swapped pumps n still nothing...everything else powers on though. You figured it out?
Blown ECU fuse. But now having issues with idle ait, IAT codes and TPS even though getting volts to all sensors. If you have a main relay you try swapping that. I assume you getting spark and fuel at the rail?
