Crank no start issue - 97 DC4 integra
714 views 6 replies 2 participants last post by  jjkz24
#1 ·
Hey forum ,
min having issues getting this 97 acura integra LS to start. It cranks but it will not start. So far, these are the things I’ve done to it to see if this is the issue.
  • checked all fuses
  • changed the main relay under the dash
  • installed a new fuel pump
the pump isn’t priming when I turn the key. I’m not sure if there is anything else I can check or do to it. I checked the fuel filter banjo bolt to look into the fuel filter is dry.
I don’t know if the previous owner put in akill switch to the fuel pump. There is a wire that is spliced into the lines leading to the pump. I’m posting a picture of the wire and new pump installed. The old one was horrible
105153
105152
See less See more
2
#6 ·
So I took the ecu off , checked the wires in the ignition , I took apart of the main relay and cleaned up the board , also checked the ground from the pump.
after I put everything back and started the car it wanted to start. 2nd crank and it turned on!
Thank you for all your help and this forum rocks!
